Airless Spray Finish Issues
Neocleous
23 Jul 2019
Warrington
Hi everyone,
I’m having issues getting a flat spray finish and I don’t know what the root cause is.
I’m using a Graco Ultra airless sprayer with a 310 tip.
Morels water based primer and paint
I’m spraying at room temperature 21C and about 55% humidity. Drying conditions are the same.
All parts have been sanded to 320 grit between coats and wiped down
When I spray some parts of the piece seem to dry super quick and leave a terrible finish when they dry.
Before I sand them and re spray again I’d really like to know what I’m doing wrong
Are you definitely getting enough paint on those parts, they look a bit thin (though that might just be because they flashed dry)? Maybe try a little water in the paint to avoid it drying too fast?
I've had good results with my graco ultra, but I pretty much only spray tikkurila paints so I've no experience of the morels.
It looks a bit like incomplete coverage —differential thickness of paint coating leading to different drying time and opportunity for levelling.
Are all parts getting the same coverage/overlap?
I think so, I’m always concerned about putting too heavy a coat down as the Graco pushes out a lot of material.
could it be some contamination of the parts? Would wiping it down with some IPA help after sanding?
im going to sand them back because they have a leathery texture which isn’t acceptable.
    140.5 KB
    187.5 KB
    157.3 KB
    175.1 KB
I normally sand and then wipe down with a tack cloth and call it good. I can't see that IPA would have a negative effect though.
Agreed on the texture, that's not ideal.
