Ed209
I do picture framing in a room in my bungalow and it has come to the point that I need a air supply for a underpinner and staple gun etc. In the room I work in, You can buy silent compressors but they are expensive and space is a premium.
I already own a fairly powerful compressor that is in my adjoining garage and was considering the best method/material to use to run a air point. The bungalow has suspended floors so that is a possible route I could also run through the loft and down.
Do you get a lot of pressure loss over a long run? I am/was a domestic gas engineer so competent soldering if copper pipe is a acceptable material only mentioned that as although I don’t have mice etc. as far as I know not sure I would want to use plastic/rubber hose unless necessary
