Hi all,
I'm after some advice. I've got a generic router table, with a Rutlands R15 router lift and motor combo in. The table itself has pressed angle legs, so is pretty unstable, and the fences aren't aligned as the outfeed side has a slight lip. I need to move the workpiece off the fence to get past the lip, which gives me the willies each time I do it. There is no adjustment mechanism for the fence. I appreciate I could potentially make something to resolve this.
I'm just a hobbyist, so I don't need a production workhorse, but I do find the functionality of a router table useful so would like to upgrade to something.
All that is to say, I've been looking at options:
- I can get one of the Rutlands tables, which obviously the lift would fit in to. Cost would be ~£500 for laminate, ~£700 for phenolic, ~£800 for cast.
- I looked at the UJK pro table which is 20% off at the moment, but seems to use a non-standard size lift so I'd need to change that - additional cost. Roughly £1000 for table + lift (I'll keep the existing router motor, sell the R15 lift).
- Alternatively I'd considered the Charnwood W030 spindle moulder as I believe there's a 1/2" collet to use router bits. Cost for this is ~£900.
- I can potentially get a 2nd hand SIP 01456 tilting spindle moulder, assuming it's still available once I've made a decision (!). This would be ~£850 delivered.
Going the spindle moulder route, I'd just be using it as a router table initially, as I already have 1/2" bits. I would then look to pick up spindle moulder bits as and when.
The options are all in the same ballpark in terms of cost, so from that point of view either of the options works.
If you have any opinions or ideas, I'm all ears!
