My comment about the frame saw is just an observation,
and no doubt there maybe some who have one on the wall behind them,
but it should be evident whether they use it or not.
I wouldn't go as far to say that there is any singular channel out there,
that caters for nearly everyone.
For a hobby, hand focused workshop, a lot may depend on your strengths and
your procurement of timber, and the work you wish to do.
Change one of those things to suit yourself in particular, and you might have some
conflicting views, different methodology, or other ways of doing things, split vs saw etc...
I can give you my personal take to try and explain
My supply of semi precious iroko timber is from skips, so have to fill and laminate timbers which is more faff than most folks need to do, i.e wouldn't deem softwood
as worth this kind of work involved,
and have a big emphasis on hand planes, and the bench for efficiency and techniques sake, and also time/fatigue wise.
Some folks with machinery i.e what someone equipped with half of Cosman's machines might own,
might deem this the most work should they be getting slabs by the truckload.
I don't need to remove vast amounts of precious material, so might be a bit of a waste of space for a hobbiest to own a P/T
Likewise the same sorta thinking can be said for hand work also.
Along with a bandsaw, which I originally sought out to resaw guitar soundboards and make a bench beforehand, lol!
I've got a tablesaw since, as I always have particular rebating cuts to remove putty, which cannot be reasonably done in the time I wish to spend by hand.
If I happened to find some alternative cheap timber worthwhile of utilizing,
I might have say, put particular effort into getting a planer thicknesser, or even by hand ala Follansbee! but as I don't have a supply of trees nor planks which I've stumbled across, I have no need to delve down that route...yet!
I've certainly got enough timber to keep me going, a decades worth of collecting, so I can cross that path of needing timber and delving differing paths in time.
Other folks might not have a stash of material, so a forever plodding clear path might not be as influential on the tools.
So it may also be a case of what/who you happen to stumble across in the mix also, might slightly influence what you end up doing,
and get what you wish to know from whoever the horse who's talking is, provided you can actually verify what the end result is.
All the best
Tom
