Phil Pascoe
What was quoted for? Altering the pipework under the floor would be an awful lot neater, but a totally different job to price for.
MIGNAL":20u50v28 said:Me layman when it comes to Plumbing.
Looks to be positioned a bit high.
Someone nearly burnt the house down.
Bends should be below floor.
It would look nice in Chrome pipes.
Chrispy":2d60u4gm said:Looks like there's a few bits missing to me.
phil.p":1f1e2jrw said:What was quoted for? Altering the pipework under the floor would be an awful lot neater, but a totally different job to price for.
Grayorm":3gnsjp2j said:Abysmal. Hope you didn't pay him. Is he Gas Safe? He has to be to touch central heating and no Gas Safe plumber would leave that mess. I take it he didn't want to go below the floor because it's laminate? He should have made that clear before starting work.
The right way to do it would be to take the laminate up and re-pipe below the floor. You would then have holes where the old pipes were (or at least one), so new flooring (unless you can match it up) required if you want a perfect job. All this should have been explained before starting work.
Grayorm":25de3q19 said:Abysmal. Hope you didn't pay him. Is he Gas Safe? He has to be to touch central heating and no Gas Safe plumber would leave that mess. I take it he didn't want to go below the floor because it's laminate? He should have made that clear before starting work.
Furthermore. When I first joined this forum a guy posted that he had started his own business doing all sorts of repairs, on anything and everything around the house. I said I wasn't impressed as he had no trade and was advertising for everything. I was berated for squashing the guy's enthusiasm, and not wishing him luck in his new venture. This is typical of what you can expect from that type of enthusiastic jack of no trade, and master of even less. I've seen this so many times over the years.
I'm sorry you've had to go through this. I wish people would take more care when choosing tradesmen. Cheapest is NEVER best.
sawdust1":36r2ygzj said:.... But Mark surely a towel is to dry off your towels not to heat the bathroom as you stated. ..
Obviously, but I for one would fit a towel rail to air a towel, not heat a room. Surely that's rather akin to saying someone bought the wrong kilowatt kettle, because it wouldn't heat the kitchen?RogerS":1nnpi94z said:sawdust1":1nnpi94z said:.... But Mark surely a towel is to dry off your towels not to heat the bathroom as you stated. ..
A radiator or a towel radiator....same difference..they both give off heat. If you have a 2kw towel radiator then that gives off the same heat as a 2kw normal radiator.
phil.p":3m8fpedb said:Obviously, but I for one would fit a towel rail to air a towel, not heat a room. Surely that's rather akin to saying someone bought the wrong kilowatt kettle, because it wouldn't heat the kitchen?RogerS":3m8fpedb said:sawdust1":3m8fpedb said:.... But Mark surely a towel is to dry off your towels not to heat the bathroom as you stated. ..
Neil Farrer":1h0gw43b said:Mark, don't know if this helps at all but here goes. This tale might be of interest to you if the company is a bona fide ltd company and there is value to the individual and company in being Ltd. If not then he can probably recommend trading in another company. If there is value to the company then you may wish to peruse a winding up order against the company. I don't know what the regulations are now but this tale happened in the early 90s.
I was a member of the Round Table organisation and the National Conference that year was held at the Rank Organisations Butlins premises at Skegness. The evening meal they provided for a section of the attendees was awful and below the quality expected of the fee so, the duty manager accepted an offer in law of a lower sum as due recompense. A credit card was duly produced, swiped and signed and the contract was amended, accepted and completed. however the duty managers boss later rescinded the contract by ripping up the credit slip later that night. Through the court the rank organisation claimed for the full fee of the meal, which I defended and after incorrectly submitting the claim and then the rank organisation failing to turn up at the specified time in court the judge found in my favour and decreed that the Rank Organisation had behaved unreasonably, which in law allowed the judge to rack up a higher level of costs against the Rank organisation. This fundamentally meant that the Rank organisation now owed me more than they had claimed against us! They failed to pay in the time allocated by the court and I then went to the post office and for a fee of Fourteen pounds filled in a winding up order against the Rank Organisation and filed it. I had the money sipped transferred within six hours!!!
I don't know whether a winding up order would work or be worth it, if the individual lives in his own house is there a possibility that you could put a charge on it against the costs that he owes you? That would make life very difficult for him and whilst not getting your money immediately it would work in the long run.
best of luck
Grayorm":2393d9r3 said:Is he Gas Safe? He has to be to touch central heating
whiskywill":1cz89uqb said:Grayorm":1cz89uqb said:Is he Gas Safe? He has to be to touch central heating
Even if the central heating is oil fired, woodfired, coalfired, electricity powered, solar powered or geothermal? In any case he wasn't touching the boiler so it would definitely not be a requirement.
Grayorm":3a7jlu67 said:whiskywill":3a7jlu67 said:Grayorm":3a7jlu67 said:Is he Gas Safe? He has to be to touch central heating
Gas fired, obviously. And how does shut down the boiler to drain it, re-fill the system and check that it re lights etc without touching it? What does he do if it doesn't re-light or there is a problem re-filling the system?
