Advice on purchasing a table saw and planer thicknesser
Thanks for the comment Patrick.
How did you find the switch over between modes on the P/T and the accuracy, did you have to realign everything when back in the planning mode.
What about the accuracy of the Bosch saw, did you find it an issue
£500 will buy you a Wadkin AGS 10 on a good day, which is in an entirely different class to most other £500 saws.
with the p/t you need to check the fence is square thats it the saw is good to go every time
If you are buying both a combi might be good value. Some have morticing attachments and spindle moulders too. There's one here 240v Combination Machine *DELIVERY* Sliding table saw Planer Thicknesser | eBay I had an earlier version of this and it was fine.
Another one here LUREM Maxi 26 Plus /RECORD POWER/, Combination Woodworking Machine, 240V | eBay the same "improved " version compared to the one I bought about 1986. It was very good and much better than expected for a low end machine, did loads of work and sold it on still working well.
Where in the world can I find a parts list for Lurem Maxi 26+ , thank you
