maryaswoodworker
If the surface is quite smooth you could try burnishing cream, it acts like T cut.
How you would do this, or whether it would work, I don't know but I was shown this tip many years ago by an old watchmaker for removing stains from the paper dials you often find on old pocket watches. Brush some Zippo fuel into the dial, then place it face down in a saucer of cornflour and leave it for an hour or so. The flour draws the fluid out of the paper, bringing any staining with it. You have to repeat it several times, but, in this instance anyway, it does work and you can go from a badly stained piece to something that looks almost like new. For a sharpie mark alcohol might be better.Try some orange oil. If you want to use cellulose thinners then mix it with some lemon oil to stop it melting the tolex and wipe it off quicly as it will melt the tolex or whatever they use these days. Alcohol should dissolve the sharpie ink somewhat. What I have found works on removing glue from acoustic guitar pickguards without damaging the finish is superglue accelerator in spray cans. I'm not sure if it's the accelerator or the propellant that does the job but it's got me out of trouble before so it might work. Maybe putting some baby(talcum powder ) on it as well while it's wet might help soak it up, it works great on silk dresses that have a panfull of duck fat spilled on them (don't ask how I know!!)
Andrew
Hairspray is a thin laquer, I don't think it's going to work on a soft tolex finish and might even seal it into the tolexTry hair spray it works on permanent marker
Could do that by building a dam with plastecine.How you would do this, or whether it would work, I don't know but I was shown this tip many years ago by an old watchmaker for removing stains from the paper dials you often find on old pocket watches. Brush some Zippo fuel into the dial, then place it face down in a saucer of cornflour and leave it for an hour or so. The flour draws the fluid out of the paper, bringing any staining with it. You have to repeat it several times, but, in this instance anyway, it does work and you can go from a badly stained piece to something that looks almost like new. For a sharpie mark alcohol might be better.
Have you considered fixing a brass engraved plate over it instead?
this crossed in the post, I'd agree but just soak a kitchen towel with milton etc and leave on the surface. see my comment for where to get these thingsmy normal stain / tack removers are 'sticky stuff remover', hand sanitiser, vinegar and acetone (last resort normally)
as you have tried all the normal solvents I'd give milton baby bottle steriliser a go, probably held in place with a wall of plastacine as per waldo's suggestion above, and left overnight
also just a thought, tomato stains will sun bleach away, maybe leave the case on a sunny window sill and see if it improves?
HiHairspray is a thin laquer, I don't think it's going to work on a soft tolex finish and might even seal it into the tolex
ANDREW
...or changing your name by deed poll?
