Hi all
I'm gonna be starting an oak dining table in a couple of weeks. I'm a bit unsure about buying the stuff though so need some advice please.
The table top will be 900mm x 1500mm x 40mm so I was gonna do this from 8x2" stock. Is this the best width to get or are there any benefits in getting say 6x2" - maybe its more stable?
I'm gonna get the timber yard to supply it faced and edged at 195x40mm. Once I've get the stock do I store it in my garage workshop or house for a few weeks before I work on it? If so couldn't it twist whilst it gets used to a different moisture level. In which case it will need machining again?
Should I store the rough 8x2 in workshop or house for 2 weeks and then get it machined at timber yard?
You'll probably gather by now that I'm prettty inexperienced at this so any advice/comments/recomendations would be greatly appreciated.
Best regards, Andrew
