Besides easier ripping of sheet goods, what are the advantages of the Felder and Minimax style Sliding table saws versus standard table saws? Anyone who has one seems to love it
I only crosscut or cut panel material on mine, and for which the scorer blade keeps the underside cut good. Can't be faffed to keep changing the blade over so I use Sedgewick ripsaw for rip cuts.Use the sliding table on my Felder all the time, straight edging waney edge boards this morning up against the shoe.
My ali slider is easily adjustable in all directions - basically the whole unit stands on four studs easily adjusted.I think there are two types of slider, both with slightly different considerations. What I call the traditional slider has a table, usually cast iron, that is not adjacent to the blade. The modern slider or panel saw usually has an aluminium table that slides against the blade.
The traditional slider allows the use of zero clearance table inserts to be used, vital for producing very thin stuff or wedges for tenons as examples. A zero clearance also reduces tear out. However, there is drag of the cut stuff that is mounted on the slider on the fixed table. This can cause inaccurate cuts if not held / clamped. Equally the slider is normal set a fraction higher than the fixed table to reduce the drag.
A panel saw is optimised for cutting panels, usually having a scribing blade to eliminate tear out. However, for traditional ripping the two materials aluminium and cast iron wear at different rates, aluminium usually wearing faster. They go out of flat faster and usually take up a lot more space than a traditional slider.
There are saws that don’t fit in either category I know, but I hope it’s a generic summary of the two, such as some of the Wadkin’s
Brilliant! Answers my question.I have as my own a saw a SCM Si15 which has a 50” slide on it. When I cut lots of sheet I place a piece of sheet on the table with a strip of hardwood attached underneath it to sit in the sliding table slot, the strip is the full length of the sheet. I attach a fence to the sheet and two stop blocks underneath to catch on the sliding table to prevent it sliding completely off the sliding table. This creates two sliding tables and eliminates any friction (it’s a traditional slider type). I can cut any size of sheet material this way. Felder used to (may still do) a thing that does the same function for an eye watering amount.
I would absolutely love to have one, would not need the tracksaw and sheet goods would be so easy BUT you need a lot of space and this is why so many use tracksaws as it is a good solution for those in a tighter space.Besides easier ripping of sheet goods, what are the advantages of the Felder and Minimax style Sliding table saws versus standard table saws? Anyone who has one seems to love it
We still use a tracksaw for a quick angled cut despite having a slider.I would absolutely love to have one, would not need the tracksaw and sheet goods would be so easy BUT you need a lot of space and this is why so many use tracksaws as it is a good solution for those in a tighter space.
I do same but the other end is on a bench. It's MDF with polish and a bit low friction.And you can do this sort of thing, me trimming half a desk top to length, with a little wheeled help!
View attachment 124504View attachment 124505
That's great, don't know why but made me chuckle. Innovation is the mother of invention. It's amazing what we come up with to overcome problems.And you can do this sort of thing, me trimming half a desk top to length, with a little wheeled help!
