Skelp
I've almost sharpened the stock blade of my number 5 plane to oblivion and I thought I may as well upgrade to a Hock or (?) aftermarket blade. One thing that concerns me is the length of the tongue (incorrect nomenclature?) on the end of the adjuster.
It performs adequately with the stock blade, but if the aftermarket blades are much thicker, will the adjuster still function properly? Is there a modification I will need to make to the adjuster, or is there an aftermarket 'fix'?
