Adirondack plans (sketchup)
13 Jul 2015
Wales
I don't suppose anyone has sketchup plans for an Adirondack chair do they?
I've come across Norms plans as a PDF which is great, but it would be even nicer to be able to print out full scale templates :D
the fine woodwork plans are cleverly scaled making the slope and the arms easy to draw out. I think you just measure using a caliper and times by 3. if your making one then the other bits can be made directly using a big compass. if your making many make a template for every shaped bit.
I don't think it's necessary to print perfect full plans as accuracy is only required between certain pairs of components(like the slopes and the legs. the arms only need to look similar)
    159.3 KB
