Abranet storgage
woodbloke
13 Apr 2006
Salisbury, UK
I've got a fair number of the Abranet sanding sheets (125x70mm) and I used to keep them all in an old ice cream tub. Trouble is, they all stick together :evil: :evil: so it's difficult to sort them out. I've just had a genius moment when I found that they'll exactly fit into plastic cash bags that you can get free and gratis from the bank or PO - Rob
That would be if you had a mixed box I suspect - if on the other hand you have one box of each grit - it doesn't become an issue. :wink:
woodbloke, I made a Abranet sanding sheet holder, the article is in the British Woodworking mag, you are welcome to the pdf file if you haven't access to the article.
Dibs-h":3ksjkax5 said:
...... - if on the other hand you have one box of each grit - it doesn't become an issue. :wink:
If it does become an issue I suppose one could always make an Issue Box.
OK OK I'm going.
Shultzy - I hope yu haven't opened a can of worms for yourself in making that offer.. Could you oblige me please.
([email protected] if the direct line is required!)
Rob
