To explain that question: For many years I used only an old Bosch PSS 230 orbital sander on various small projects such as shelves. I gave that sander hours and hours of use over the years, and developed a way of working with it that would see me going back and forth many times over a surface until I could see fine detail in the grain emerging. By the time I'd worked my way up to 150 grit, the boards would almost shine. About 10 years ago, when fitting oak worktops in a kitchen I bought a 4" belt sander, which now use up to 120 grit, which was fine for the worktops but I'd sometimes still finish other things with the Bosch and 150 grit.
I needed to replace the Bosch over the last couple of years and following advice and reviews here and elsewhere bought a Metabo 450 duo and a small Makita palm sander. I also invested in a pack of various grades of Mirka abranet 'ace' discs.
I used the palm sander as the finishing sander on some burr elm window boards last year and was really pleased with the results - a bit poetic maybe but in certain light it really looked as though the elm was shining from within with its own light.
I've just finished a board from some of the same burr elm for a friend. This time, after initial work with the belt sander, I just used the duo with Abranet on the finer finishing orbit setting. I took it through multiple grades down to 320 but I wasn't really happy with the results. The board felt smooth enough, and I'm fairly sure I took out any sanding marks from each grade of grit, but I found it quite hard to tell when I'd done enough with each grit and move on to the next grade. The finish seemed quite matt at the end and generally a bit dull and lifeless compared to what I'd expected.
I wonder whether there's something I'm not doing 'right' with the Abranet - it gets such positive reviews here..! - or whether it does produce a different kind of finish to aluminium oxide..?
