AA-AAA Batteries
Kayen
22 Nov 2021
Grimsby
Has anyone worked out the best value for money batteries, and can make a recommendation on what and where to buy them?
I remember the good/bad (take your pick) old days when batteries were batteries - now they're just confusing with so many options, or at least they are to me.
I have enough chargers in my house, so I prefer single use batteries, but all recommendations would be appreciated. TIA.
these rechargables https://www.screwfix.com/p/gp-batteries-recyko-rechargeable-aa-1-2v-ni-mh-batteries-4-pack/545rm cost me £10.99
I could have bought non-rechargeables for a quarter of the price and would have burnt through them many times over by now, along with the hassle of buying more and/or finding you don't have one when you need one.
I have a night light for my kid that uses AAA's and I've recharged them more times than I can remember. If I'd used non-rechargeables I'd hate to think how many I'd have gone through by now.
Other than a few applications like tv remotes and clocks I don't bother with non-rechargeables, but each to his own.
As a rule of thumb I try and buy rechargable items, it just feels better value and better enviromentally than disposables.
However, when it comes to AA / AAA batteries, if I have to use them I use disposable primarily, this is because a disposable puts out 1.5v and a recharable 1.2v at full charge, so for most equipment if you use rechargable it will be read as a near dead battery. I know this is a simplistic way of describing output.
I buy bulk packs of panasonic or varta from the screwfix counter occasionally. As long as they have a long date printed, cheap is what tempts me. The panasonics seem better.
I have a lot of pricey electrical test gear where a leaking battery would be a big deal. For these the only batteries I'll use are the energiser ultimate lithium because those are made for long life and I've never had one leak even after 10 years+ , or rechargeables (a couple of dozen eneloops).
I had some bad leaks from duracell years back so I trust them the least.
I keep a simple list to remind me to check batteries every year even if they're still good.
The CR2032 and LR44 cells in stuff like verniers, micrometers, welding visors, remote controls, are easy to forget but much cheaper in 10's from batterystation, etc online.
Buy from somewhere with a high turnover so their stock will always be fresh wirh a long expiry date.
It depends on the device, batteries that you don't expect to last can generally be rechargable provided the appliance can tolerate the lower voltage. 90% of the time it's a non issue because anything that can't use rechargeable will leave a good chunk of unused capacity even in primary batteries.
Things that don't draw much power, e.g. clocks, remotes etc, alkaline all the way. Don't care about brand, cheapest is best within reason. Don't bother with zinc (carbon or chloride) - they are frequently a little cheaper but nowhere near the capacity. Equally lithium are better but unlikely to be worth the premium except to save weight or in particularly long-life applications.
I have experimented with low self discharge NiMH batteries but found them underwhelming, may last six months in standby style use but not much more than that. Those were Amazon-branded AAAs, picked up a pack of precharged AAs from Lidl a couple of weeks back, not sold as low self discharge but must be to be precharged. I'll have to see how they go, 8 hi cap AAs for a fiver was worth a punt and good value even with the self discharge element.
Only place I used branded batteries is in a couple of very long-life applications, I'm thinking here of a couple of mini UPSes providing standby power to small network switches at home. For simplicity I built those with disposable batteries, they don't try to charge them. I use Duracell's there since they come with an 8 or 10 year shelf life. In the absence of a power cut you can swap them out after five years and put them into general use, giving you the standby element "for free" as it were.
Non rechargable batteries are just crazy as far as I can tell. We have been using rechargeable aa and aaa batteries for years the kids have tons of things that need them. I only have one charger that will do 4 at a time ( technoline BL700 ) but always keep a bunch ready to go. I must have saved hundreds of non rechargeable batteries from landfill by now. I get the Eneloops or the IKEA ones normally but the Lidl ones are actually fine.
You can also get usb C chargeable ones which are 1.5v but I have not tried these.
20 odd years ago I worked in electrical wholesaling. The best battery by far was the Duracell Pro Cell.
They were at the time higher capacity than the standard Duracell but were considerable cheaper due to not being retail packaged and could only be sold in box quantities, and not supplied to the public only to trade accounts, they also used to be guaranteed not to leak
Previous posters correctly point out that rechargeable generally operate at 1.2v which can show early faults on equipment
A good few years later i ended up working for 2 of the blue light services both of them will only use Duracell Procell and there are no rechargeable standard batteries permitted to be used on any equipment
That to me says a lot as some of the items that are powered by AA's AAA's etc could be mission critical.
I acknowledge that your TV remote is sort of not mission critical.
Procell is the only battery in my battery box they generally come with really good dates and up to now I have never had one leak, however i acknowledge that they aren't the cheapest.
