davedoublem
I'm going to be starting a plaque project using a square piece of relatively thick wood. The size must be 130mm x 130mm and ideally the depth should be 18 mm-25mm. If all goes well then will be looking for regular on going orders.
Im painting the wood white and there will be a small razor hanging on the back of frame which will include small screws in the back.
I require a smooth wood with little to no grain that takes paint well, and wondered if mdf may be the most suitable to use? If so, would it hold up to small screws inserted in the back?
Also are there any decent competitive wood cutting companies in the UK that can cut to the thickness required?
