Regular readers will know that there is a nice man in Oldham with a big nose and a cheeky grin... I say he's a nice man, but he's a bad man really as he keeps showing us nice tools and then offering some of them for sale!
I can only resist so long, and so I am now the owner of Mr P's rusty shoulder plane with the condition that I take some pictures of what I do with it.
So here are some.
As you can see, it's a user-made shoulder plane of riveted construction, with a few cosmetic challenges, such as rust and paint spots, but I think I can deal with them, and make some sort of silk purse from it, maybe, one day.
I couldn't resist making a start.
The main problem seems to be that the back has been hammered a bit too much. The maker gave it a screw to hammer on, but it seems to not be supported on anything, so years of hammering have forced the screw into the infill, wedging it apart and opening up the sides
Consequently, the sides are not flat:
So, the first job was to get the screw out. It was a socket screw but the socket must have been an imperial one and I only have metric allen keys. A torx bit looked like it fitted but just rounded off the socket, so that was no good.
I tried cutting a slot with a mini tool and a cutting disc
which worked, but the screw would only revolve, not unscrew. I drilled a small hole down it and pulled it out with a hardened woodscrew.
I could then see that, as I had thought, the screw only went into the infill. As well as wedging the plane apart, it was not quite central. I plugged the hole with a bit of wood and drilled a new hole more nearly in the centre.
Into this I shall fit a bigger screw which will bridge over onto the metal like this:
It's just pushed in for now, but I shall glue it in place.
The infill, as Mr P said, looks like plywood, but when I was cutting the screw (and so making it hot) it gave off a distinctive smell of old circuit boards. I think it might be a synthetic resin bonded plywood, made up of many thin veneers. As such, it's ideal for the purpose, so it's staying there!
The wedge is badly mashed, but I think I can cut it back to a decent shape.
Also, the blade is very thin - I think it must be from a bit of hacksaw blade.
It's also too short - there is nothing to hit behind the wedge:
so I shall be off to Bristol Design to look for a better iron.
That's all for now: more soon, or when I get the time!
So here are some.
