A new workshop
dedee":23dkp6c5 said:
Stef, I've read elsewhere of Tongue Tite screws being very good for fixing sold wood floorboards http://www.screwfix.com/p/tongue-tite-s ... -200/85991
Some seem to say that pilot holes are necessary to stop the tongue splitting others do not. Some suggest that screws do not allow for movement in the same way that nails do.
Are you sure a couple of days is enough for acclimatisation?
Andy
yep, i am over enthousiastic here, it will probably be a week or two before i screw/nail them down !
i think also nailing would give more room for movements, but then i can also change the screws to nails, whereas chaning from nails to screw would be a little more difficult ! looks like its going to be screws !
The last two t&g floors I've done I've secret nailed with a porter nailer (neither floor has had problems in around 4 years).
The floor boards are now down.i havent screwed or nailed anything just yet.
I also havent cut the last set of boards to size, just so that i'll have enough left in case of massive shrinkage !
Finally, i ran the flexible tubes in which i can feed the power cables for the additional sockets i am fitting.
I even ran two so i can have wire floor sockets (thanks andy !)
The pine is all clean and new, but marks very easily with black sole trainers... but that's ok, i guess it will soon turn grey anyway !
Looking good Stef.
I'd be tempted to put some sort of finish (floor varnish perhaps) down on the floor. It would prevent the wood from staining if oil, paint etc is spilled.
Andy
dedee":2bqzfctf said:
Looking good Stef.
Andy
thanks !
I've just found a source for the screw you mentioned earlier. 8euros for 200, plus 12euros pand p :-(...
i guess i'll try to find a cheaper source, and failing that, i will nail them !
I have some left over underlay, that the former owner kindly left me, about 9sqm worth of the 7mm thick, green felt type thing.
I am thinking about cutting it in strips and use this between the boards and the joists. I will prevent the floor from squeaking !
They sell something equivalent at LM..
Stef, I've not looked for those floorboard screws over here before. The key is their "lost head" . I'd be surprised if there was not an equivalent over here from a quincaillerie perhaps?
Mail order over here seems to be in the dark ages, many companies only sell to professionals (siret required) or postal charges are prohibitive.
Andy
Progress has been good during the christmas break. I managed to insulate the whole shop, and i have almost finished the electrics.
Three phase supply means a lot of wires comming out of the walls. i managed to sort out the spagheti..
Everything is now back in the shop
you will notice my new tool cabinet on the right here... i am having all the windows replaced, so i managed to have three like this one put aside for me, the have roller shutters, and are just deep enough to house a number 7 plane..i'll put more picture of this later on.
I will have to connect all the bits on the CNC as soon as i get a chance. I managed to do the first cuts with it before christmas, but had to take it all apart again to do the building work in the shop.
Stef,
that really is looking good, I will pop over one day when it's finished
Andy
Right, now that the workshop is functional and almost complete, i thought i'd post a few pictures. so here they are:
second rotation from the door to the house:
and the tool cabs, which i am pleased with:
there are still a few wires hanging for some more light, ceiling sockets, and dust extraction. That will be for later.
Overall, the workshop is spacious, and the floor is very comfortable. Most units are on wheels, so the machines can be moved around to suit. There is plenty of light too, from the two french door, 4 neons and central bulb. It's a double door to get back in the living quarters in the house. so the noise is fairly well confined.
