Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 76
The buses have gone up again. I'm getting a paunch. My stamina ain't what it was.
Add that lot together and the 2.8 mile trek from home to the centre of Bristol (where the office is) begins to look inevitable ("... Mr. Andersen."). And yes, it did me some good,* I think.
But it has expensive drawbacks. Obviously, for someone starting out on the return to fitness thing, meandering is impractical - the shortest trip is probably the most sensible, but there is a huge snag: my direct route takes me down St. Michael's Hill and down the celebrated Christmas Steps, into the middle of the city.
You've probably guessed: that's less than 20ft away from the spiked mantrap that is Bristol Design.
I had enough self control not to go in until my way home, only half an hour before it shut (how much damage can anyone do to their wallet in 1/2 hour?). Well I escaped with only slight pain: a 3/8" socketed mortice chisel for £7.80.
It's the classic "pig sticker", but seems to be of laminated construction, with a different steel on the edge and reference face. Obviously I can only clean it up so much with abrasives - it's going to be more of a nuisance if it's significantly undersize, but I have to make it a new handle at the very least.
The "handle" was quite extraordinary. It has two rusty tacks in it (one was inside the socket) and what seem to be staple holes. I think it's oak, but I'm not sure. I've never seen the maker before, but I know little...
The stamp was invisible before cleaning, which might have been to my advantage--or it might just be rubbish quality, anyway.
You can tell by now I know little about mortice chisels. I've never owned one before , and this one is supposed to be a user, not a display piece.
So here's my problem: is there a standard taper ratio for the sockets, and is there a clever process for fitting them? I don't own a lathe, but I have some offcuts of hardwood curtain pole (about the right diameter) that might be suitable - it's going to get well clobbered after all, so aesthetics are secondary. I'll probably band the end with a ring of 22mm copper pipe (or possibly a brass olive!), but I'd like to make it as strong a fit in the socket as possible.
I had a play about yesterday with the bandsaw and a taper jig, and I can cut reasonable cones in the curtain rail "stock" (finish off with spokeshave and sandpaper). My problem is that I can't seem to measure the taper very well, and, as you can see the 'handle' it came with isn't a good guide.
Before I go for wax casting the internal shape or something similar, can anyone point me at a set of instructions, to save me wasting feet of hardwood?
All advice considered, but I'm already planning an alternative route to work, in case it happens again (they have wheelwrights' and chairmakers' tenon cutters, too!).
Thanks,
E.
*one afternoon meeting a fortnight isn't going to kill me. But it won't get me fit either. :-(
Thanks,
E.
