A New Hall Table Project FINISHED
Lord Nibbo
18 Oct 2005
Near Looe, Cornwall.
It's been in the design stages for several weeks now.
An American Black Walnut Hall Table.
Early design had three drawers and through tenons in the table top.
Revised pic
Extra detail
Drawn with metal handles but I think it will have wooden handles when built.
The final design
With some redesign of the top. Out go the through tenons, in come two outer rails with the grain running the length with the centre panel having the grain running across the table. Not decided as yet but I might add a very small chamfered edge where the two opposing grains meet.
Dimensions 60" long, 16" depth, 30" high
Like the idea of the chamfer between the boards on the top. The design looks very modern yet classical, but there is one thing that stands out to my eye as not right. It's the joint for the stretcher, I reckon a wedged through tenon would look much better and give an overall harmony to the design
Hmmm! :-k I'm open to a vote on that.
I really don't think that wedge looks right on a piece like that. Is it not supposed to go with the other pieces you have made recently?
Aidan
Not a fan of the wedge joint either. Look forward to the end result.
I agree with Ironballs. The original design for the stretcher would be more in keeping for something like an oak refectory table, but not for a hall table in American Black Walnut.
Cheers :wink:
Paul
Aidan
Although not in the same room as the cupboard unit
Or the drawer unit
Yes I do want a sort of match to a chunky modern look with clean lines no frills.
So that's one for wedges, one against wedges. :lol:
(edit) 1 for, 3 against. :(
Another thought, Your Lordship. Will the top be in solid wood? If so, will you get any problems with the different grain directions, with expansion and contraction? Might be better to make the central panel from veneered MDF :-k
Cheers :wink:
Paul
Cheers :wink:
Paul
:lol: :lol: :lol: I've been waiting for someone to ask about opposing grain, your the first Paul.
But I've pondered over it for several days, I do have a solution planned. That's why I mentioned small chamfers, it's part of the plan. 8-[
Well your other piece has very clean lines and that external wedge looks a bit rustic on your new design, in my opinion they wouldn't match
i agree.
I've started cutting the wood for the top, everything was thicknessed i.e. the two outer rails and the short pieces that will be the centre panel were also cut to length. Everything was matched up and marked. Now all these pieces will be kept in the house to acclimatise, none of the top will be assembled until I’ve finished the base & drawers.
The foreground in this pic shows the shorter lengths laid out and marked up for matching, in the background are the two outer rails of the table top.
A closer view of the pieces
Next will be sizing the wood and making up the base. :)
When are you going to reveal the cunning plan, Your Lordship? My guess is that you are going to have the two outer rails of the top fixed to the base and the central panel "floating" between them, secured possibly with loose, un-glued tongues.
Cheers :wink:
Paul
Come on, that's not cunning, even I guessed that one, there must something more, surely??? How about temperature compensating bi-metal strips below the top which change the length of the table when the sun shines on it?
Aidan
Cheers :wink:
Paul
I'm afraid you'll have to wait right to the end,
Paul Chapman":2zms8u8k said:
Ah, a cunning plan :lol:
I don't see that using a turnip in the table design is going to help? :roll:
I do like the look of this timber, every time you post pictures of it I am a bit jealous of it. :oops:
I do like tusk tenon joinery but, I don't feel it looks right as part of this piece either. A wedged through tenon would probably look best, as suggested earlier. Often the wedges are cut in a contrasting timber - would that work against walnut with a light timber? :-k
That's not a bad selection of ABW either. I think you once said you buy it from Lathams in Yate - is this from the same lot? I've got to buy some American Cherry soon and I may give them a try. Their quote wasn't the dearest I've come across, either.
