Forgot to add - achieving that 500 lux light level consumes around 80W, which may sound excessive, however I rarely use it at that level since it is almost uncomfortably bright for 'normal' use!
I fitted led 1200 x 600mm panel lights up in our village hall, they probably are on 50 - 60 hours a week, been up for about 4 years now. Never had a panel fail, but had several power packs fail. Fortunately, easy and cheap to replace.Having worked where the life expectancy of semiconductor lasers and LEDs had to be quoted leaves me wondering about the life quoted for LED lights run from mains electricity. LED component life is generally 30 - 40 thousand hours but what about the other components in the 'light bulb' required to tailor the incoming 220VAC down to the 10VDC or so to power the LED? Those will have a lifetime as well and some will be under more stress than the LEDs.
PS not sure of the voltage required by the LEDs used in lighting but it will be DC and it will be of the order of 10V or less give or take.
