Bluekingfisher
I have a rudimentary grasp of the router, however, and although I own a few, I have never utilised their range or expanded beyond the relative basics. Why? I don’t know, I suppose because I have often found a way of getting the job done without the mess, noise and fuss associated with setting up a router.
Having purchased a Leigh dovetail jig a couple of years ago I thought it about time I pulled it from the box and makie use of it.
I know there are some great routing aficianados out there so I am hoping some one can point me in the right direction??
The Leigh jig makes use of 8mm cutters, and although most 1/2” routers come supplied with the additional 8 mm collet to fit the smaller cutters, the router itself can be a fairly weighty machine, which may be difficult to control when edge routing or when working on a dovetail jig
So, my question, or questions are as follows -
Is there a preferred router for use on dovetail jigs? would a mid size 1/2” router due to its smaller mass be more effective, comparative to its lesser power output. If so, which models are recommended?
Is a plunge or fixed base router more suited to this procedure?
Alternatively, should a dedicated 8mm router be considered?
Is a variable speed control necessary for this particular operation?
Dust control – The jig is supplied with vacum attachment, will this be enough to deal with chips and dust. Or, is a vac attachment for the router required, or is the additional hose to the router just an unnecessary obstruction?
Sub base – The bushing supplied with the jig may only fit specific routers, will I have to consider the additional expense of a sub base?
Quite a few questions there guys and gals I know but if anyone would like to take the time to share their experiences or advice then it would be greatly appreciated.
Many thanks in advance
David
David
