90 degree joint for lean-to roof joist
Chris152
26 Apr 2017
Cardiff
Excuse the rather rudimentary artwork :) but I need to join a joist to the one (temporarily) in situ. It'll have to support further 5 smaller joists (2"x3") that will in turn support a plastic corrugated roof. It'll be joined to another 6x2 at the other end (it's 3m long).
What joint should I use for this?
Thanks, Chris
EDIT - On reflection, I think the easiest and strongest thing is to add another vertical post at the junction of the two joists, so both can attach securely to it and it's further supported onto the ground.
Problem solved, I think!
OK, Mostly in place now. But what is the correct screw spacing for miniature corrugated plastic sheet? I've searched the net but can't find the answer.
Or let a corbel into the existing post to support the new Rafter.
It all accords where you live and the loading you expect on the roof, high winds and snow then closer spacing, it's up to you, personally I would only want to do this once so would go with 450mm spacing.
If you use the onduline bitumen sheets on any pitch less than about 30°, I have found you need to space the battens at about 300mm, otherwise they will tend to sag between them over time. Steeper pitch and 450 is fine.
Thanks, Chris
Joist hangers? Lots of shapes and sizes
https://www.speedyfixings.com/builders-metalwork/joist-hangers/
These are the ones we bought today. Went to Trago Mills in Merthyr, a mind-blowing place on account of the size of it, like Heathrow airport but with stuff. Also somewhat like a vastly extended Middle-of-Lidl.
https://www.trago.co.uk/3050mm-10-m...QjtmrLLo5lfGcCaqkw_aem_mVi9mavdFzMcGLGF38m6eA
Much cheaper than anywhere else, and exactly what I wanted. (Well, I really wanted a clear glass roof, but £££).
If they are like the ones I have used before they are surprisingly strong. I would think 450 is probably ok. Problem with the bitumen type ones is that in the summer when they get hot they become a bit softer, so apt to sag. Certainly I found that on a roof with the ridge orientated broadly east west it was the south facing ones that suffered this problem more.
Only problem I have found with the clear ones is that if they are not firmly held down they can vibrate in strong winds and then you can find cracks developing round the fasteners. You need to use soft plastic fastening cups. I would say probably one fastener for each 200mm of width, further apart if it's in a sheltered spot.
Thanks all.
I'm struggling with the final step - I can't figure out the fixings to use for mini profile corrugated sheets. These are the ones made by the manufacturer (Corolux):
https://www.trago.co.uk/corolux-miniature-profile-fixings-pack-of-10.html
It seems a bit odd to try hammering them into position on such a fragile sheet, especially as there will be about 45 per sheet and 5 sheets - plenty of room to make a mistake!
I'd much prefer the usual screws with caps, but wonder if they'll leak - any thoughts or experience with this?
It's a bit like using a powered screwdriver you become an expert of knowing when to stop just after you have finished. 🤔
Thanks all.
The spacers look good but the nails!
Not installed a lot of clear corrugated but fixed acres of the regular sort down and generally use screws like this https://www.screwfix.com/p/easydrive-flange-self-drilling-roofing-screws-6-3mm-x-80mm-100-pack/5672p
Yes, I was looking at that sort but wondered if they would actually seal the small profile ones. They seem to recommend them for corrugated metal and again, I wonder why not plastic?
I may try to get a small quantity of those, and of the regular profile pvc sheet sort, and try them out to see how they go. Another option is to get the Corolux ones and swap the nails for screws, but I think we'll need about 200 of them, which could drive me nuts.
I have used this type of sheet for many applications, (I absolutely agree with the previous advice about support) I substituted the nails for screws with the clip down covers, I used the green outdoor screws (Toolstation et al). No problem with leaking. The single sheet type do however suffer from condensation when it is cold overnight (ask our horses!) and that is worse than leaking. In my barn I put a single strip of glass fibre corrugated sheet to give light and the rest of the metal barn roof has a fabric wicking layer. There is a huge amount of condensation dripping from the clear section but none elsewhere.
Thanks XT - To be clear, did you use this sort alone:
https://www.screwfix.com/p/essentia...Vv6ODBx0ZqzL6EAQYASABEgL1cPD_BwE&gclsrc=aw.ds
or those in combination with the seal from these:
https://www.wickes.co.uk/Wickes-Mini-Profile-PVCu-Sheet-Fixings-Pk-25/p/142214?gclsrc=aw.ds&&utm_source=google&utm_medium=cpc&utm_campaign=PMAX Shopping - Roofing&gad_source=5&gclid=EAIaIQobChMI6M_jqcTIiQMVTZRQBh2PcA-pEAQYASABEgL6e_D_BwE
or some other combination (you mentioned the green outdoor screws)?
Chris152,
Yes the ones like the Screwfix type. I seem to remember they came in much larger quantities and possibly without screws just the caps, probably bought with the sheets from the roofing supply company. I used c/sk screws, the green ones were quite thin 4.5mm (?), I also drilled the sheets first with a 5mm drill. Do not overtighten let the cap do the work!
Chris152,
Sorry to be a pain, but you seem to have the answer I'm looking for - you used those in combination with the little seals that come with nails (which you removed), or on their own? And yes, I can see just the caps for sale from Amazon, I could get those and use my own screws.
And - according to the company that made the sheets, you use a masonry bit to drill the holes - seems a bit odd? I'd have thought a wood bit with a sharp pint to locate it would be better?
