90 degree joint for lean-to roof joist
Chris152
26 Apr 2017
Cardiff
Excuse the rather rudimentary artwork :) but I need to join a joist to the one (temporarily) in situ. It'll have to support further 5 smaller joists (2"x3") that will in turn support a plastic corrugated roof. It'll be joined to another 6x2 at the other end (it's 3m long).
What joint should I use for this?
Thanks, Chris
EDIT - On reflection, I think the easiest and strongest thing is to add another vertical post at the junction of the two joists, so both can attach securely to it and it's further supported onto the ground.
Problem solved, I think!
OK, Mostly in place now. But what is the correct screw spacing for miniature corrugated plastic sheet? I've searched the net but can't find the answer.
Or let a corbel into the existing post to support the new Rafter.
It all accords where you live and the loading you expect on the roof, high winds and snow then closer spacing, it's up to you, personally I would only want to do this once so would go with 450mm spacing.
