I’d love a 12 or 14” bandsaw to do all sorts with, but after checking available space in the back of my shed, there isn’t even room for a record power 250.
I’m not really looking for anything for resawing, but I do want to make little ornaments etc - things like this
It seems I have only a couple of choices at 9”, and I’m deciding between the Axminster AW1400 and the Lumberjack 9”, which looks to be the same as a Draper and a Clarke 9”
It feels like the Cast Iron table of Axminster is the key feature, though the extra cutting height of the Lumberjack is nice. I don’t know the trade off between power and blade speed in these two either.
Keen to hear recommendations on 9” bandsaws for small free hand cuts, and I expect some shape and straight edge cutting from small 19mm boards.
Key differences:
Table
AX Cast iron table
LJ Die cast Aluminium
Cut height
AX 80mm
LJ 90mm
Power
AX 250w
LJ 300w
Blade Speed
AX 800m/min
LJ 635m/min
Blade Size
AX 1400mm
LJ 1574mm
Key differences:
Table
AX Cast iron table
Cut height
AX 80mm
LJ 90mm
Power
AX 250w
LJ 300w
Blade Speed
AX 800m/min
LJ 635m/min
Blade Size
AX 1400mm
LJ 1574mm
