8 bit inside out candlestick
Jonzjob
UKW Supporter
19 Mar 2007
Ex nr Carcassonne, France. Now Corston Malmesbury
As some of you know, I'm always up for a challenge and earlier I had posted some photos of what called inside out turning. Too long to explain here, better to do a e=search on it if you haven't heard of it before.
Well, I have made a 4 section followed by a 3 section jobbie which turned out a lot better IMHO. But, I thought 'I wonder if it's possible to do an 8?' So armed with a lump of beach wood, about 8" long by 4" square I sawed it lengthwise in to 8 segmenta, like an orange, turned them inside out and glued them back together. Turned a waste like form inot it. Then split them back into the 8 bits and turned them back the original way. That gave me the same internal form as a 4 bit, so I rearranged them the right way out but in a different form and glued them back together again. This time as a permanent fixture.
Back onto the lathe and turned the outside to the shape I wanted, heart in mouth and ready to duck toot-sweet (as the French would say?) No bits flew off and it took the shape I wanted.
I wanted it to be a candle stick to take one of my 3" spherical candles so a curve was shaped in the top. I finished up with
8 bit inside out 2 by John, on Flickr
I didn't want the candle just to sit in the dip in the bare wood. I have some zinc drain piping left over from fitting some rain water tubs. The zinc is a nice silvery, shink, soft metal, so i wondered??? So I opened up a bit of it. It's only soft soldered, and cut about a 5" square
I turned a press for it
8 bit candle stick zinc 1 by John, on Flickr
8 bit candle stick zinc 2 by John, on Flickr
And employed my 6 tonne log splitter :D:D to put a bit of pressure on it, as you do?
8 bit candle stick zinc 3 by John, on Flickr
And finished up with what looked like a floded silver handkerchief
8 bit candle stick zinc 5 by John, on Flickr
It fitted beautifully into the dip
8 bit inside out 3 by John, on Flickr
And the candle fitted as if it had been made for the job
8 bit inside out 4 by John, on Flickr
I still have to give it a coat of herd wax oil and polish, but all in all, I like it and it is very different. The holes are alternate high/low as I turned the even segments upside down to get the effect I hoped for. That is why it isn't as good a join as I would have liked in places?
C'est la vie..
It's nice to see something different! I have a suggestion for the zinc liner - have you considered metal spinning? You could spin a disc of the thin zinc over that wooden former and end up with a dish with no creases.
Ta folks.
I was going to gently BASH it to shape, bur decided to try to press it instead. I quite like the silver hanky look to it. I have to admit that it looks better in real life though.
I might try the spin/plenishing method? I have enough of the drain pipe left to have a few dozen tries at it :mrgreen: About a 6' length of 4" diameter pipe! It's amazing just how soft it is and it's quite popular and easy to buy here in France.
