7.5hp 3 phase spindle off domestic 240v
flanajb
UKW Supporter
11 Mar 2009
I'm more curious on this one, but could you use a static / rotary converter to power a 7.5hp 3 phase spindle off a 240v supply?
you could with a decent cable to the workshop and be best with a rotary converter but an inverter with a dual voltage motor would be less stressful on the supply and you might get away with a 32amp supply to the inverter.
See the table I posted here Three phase table saw
I've just checked and I have a 40 amp breaker in the house and 10mm armoured to the garage. I suspect with voltage drop that would be on the limit.
Does the machine have a dual voltage motor? If so then an inverter will be the way to go and particularly useful as you can vary the spindle speed for different cutter diameters.
