Didn't bother taking photos of me painting the MDF panels so I continue by slotting the panel into it's slot...
No need to glue the panels as they fit nice and snug into the slots. I fit the centre piece then dropped in the 2nd panel and fitted the end...
that looks twisted in that photo above but I can assure you it's not. Trick of the photo.
I'm enjoying this, seem to be making good progress today. I assembled the right hand side next, same as the left.
I decided at this point that I needed 3 pairs of arms. I had to put the rear together which required some cunning propping up of the side panels. I fixed the bottom rail in, then slotted the 2 rear panels in place and then from the top I inserted the centre upright. Slid it straight down. I realised it didn't fit. Much head scratching to be done for the next 10 mins while I work out what on earth I'd done. Looked like I'd not gone deep enough with the slots on the centre piece and I needed to run the router down them again taking out 2mm from each side - sorted, put the top brace on and the front braces too, stood back and admired my work... with pot of tea in hand of course.
got distracted for a while cos some people came to buy some bird boxes I'd made from pallet wood. I put them on the wall at the end of my drive and get a fiver a piece for them.
Right-o, ten quid better off I returned to my masterpiece lol
As I'd chosen to screw/glue the frame together I was left with 8mm holes in the frame. Now I'd planned this so the holes were all in the same place all around. I took an 8mm dowel and went around the whole frame glueing the dowels into the holes...
then when dried I trimmed them with my flush cut saw and gave them a light sanding down, nothing to serious though because the whole thing needs a good rub down later (oo-er)
The top for this unit had me stumped for a while. Couldn't decide on what to make it out of then I spied my pile of timber I'd not allocated for a job yet. Thought I'd knock up a top from this and if it doesnt look any good at least I'd not forked out for good timber. A lot of planing up needed though, wish I'd of bought a thickneser/planer now.
The rough cuts...
Hand planing the edges...
isn't this what every woodworker wants to see? nice long smooth shavings...
I put biscuit slots into the edges of the roughly planed timber (I'll be planing it a bit better once it's one piece)
and clamped it up...
and that concludes todays events. More to follow...
The rough cuts...
