38mm hose - Y Junction
Can you not bodge it with a 40mm solvent waste qblique tee, cost about £1.00 from B&Q
Jason
Thanks Jason, for a quid it's got be worth a fiddle. I am surprised that APTC - and others from Googling - only seem to offer a steel variant.
Andy
Andy - if the fit's not quite there a couple turns of duct tape over the joint will usually do the trick. If it tends to come unstuck then I've used a some cable ties over the joint to secure everything...works a treat - Rob
