Ttrees
Iroko loco!
Howdy folks
Was using my bandsaw recently for processing my reclaimed wood ...
In an attempt to cut behind the putty on a lot of stock I have, I inevitably cut into some, and my new blade
lost its set on one side and I ended up fighting with the saw trying to cut the rest of this waste off the rest
Upon turning my saw on again my Huanyang VFD seems to have failed as its showing a "DL" error code.
That means short at output
Lesson learned, Don't put strain on a motor with a VFD !!
Should have tried sorting the blade straight away, regardless of the time involved making a tooth setter
or whatever.
Anyway I stripped the VFD apart....again and found nothing wrong with it.
No smell or melted anything.
I have read up on this, and apparently the spindles that come with these can burn up also.
This prompted me to take the motor terminal cover apart and have a look.
It smells slightly burnt, but no sign of melted anything.
I then tried the VFD on another motor, and lastly the tablesaw motor I have running,
and this DL error shows up on all of them.
So the VFD needs work ....
What I am concerned about is the ABB motor on my bandsaw
I have not connected the good Huanyang up to it yet because, I thought it might need maintenance work.
I only have a multimeter and resistance testing requires a Ohmmeter or a megohmmeter from what I gather.
I must admit, I never took the casing of this motor apart to inspect anything, but it looked really clean from the outside.I think I would have smelled the terminals if it was like this before.
No smell from anywhere else, yet ... Its still on the machine, I have not disassembled it.
What procedure should be done next ?
Buy a cheap megohmmeter or Ohmmeter from China ?
I've seen on YT people using motor varnish on the coils
Should this be done ?
I cannot find good info online for my situation
Any help very much appreciated
Tom
or whatever.
Tom
