Hi all,
I need to put 3 phase sockets into my new workshop. I should have this done by electricians but I cannot currently afford to do so, as I’ve had to pay out a lot of money.
What I’m going to try and do is install the board, sockets/isolators and cable myself, which should cut a two day job (for the electricians) down to a 1 day job.
Having a look around, it’s of course more complicated than I thought it would be, so need some help identifying the right parts and any deals that anyone might know of, that can help me save more money.
I have 5 machines that need 3 phase:
1 x Bandsaw 5kw (8amps)
1 x Planer 5 kw (8amps)
1 x Wide belt sander 10 kw (28 amps)
1 x Panel Saw 4kw (8 amps)
1 x Dust Extractor 4 kw (8amps) The extractor already has cable and isolators going into a controller so is not part of this equation.
All of the machines have cable and sockets on and are ready to be plugged in to a wall socket/isolator.
I’m going to go with 32 amp wall sockets/isolators (unless suggested otherwise)
What I’m struggling to identify is the start up amperage of each machine, which will dictate the thickness of cable and breaker, unless that is already given in the overall rating?
2.5mm core cable rated at 31 amps will be fine for the 8amp machines and potentially the 28 amp wide belt sander; unless start up amperage exceeds that?
4mm core cabal running into the board from the main board (3 phase inlet into the workshop) rated at 42 amps will give me enough power to have 2 machines running, (extractor + machine).
I could though bump this up to 6mm core and get 53 amps, in case I want to run 2 machines plus extractor?
I need breakers but not sure which ones. I know for example, the wrong breaker was fitted on the wide belt sander before, and the electrician changed it to one that although rated slgithly lower than the amperage, it was a ‘c’ cat one (or something), so it could deal with the load.
Components: (This is a list so far)
1 x 8 way board 125 amp TP+N Type B (not sure what TP + N and type B means) https://www.cef.co.uk/catalogue/products/4887747
4 x 32A 4 Pin 415V Wall Mounted Interlocking Socket https://quickbit.co.uk/32a-4-pin-415v-wall-mounted-interlocking-socket/
15 x mtr 2.5mm 4 core armoured cable https://quickbit.co.uk/swa-cable-4-core-2-5mm-per-metre/
15 x mtr 6mm core armoured cable https://quickbit.co.uk/swa-cable-4-core-6mm-per-metre/
Any help would be much appreciated.
