toolsntat
Yep, I collect tools and tat
These have handles but really need cutting off and something more appealing fitting . Both for restoration if desired or a handle and a grind will make em usable .
£5 each
Cheers Andy
Near Hinckley
You can become a Supporting Member or just click here to donate.
KimG":l8xac9bu said:I'm interested in the clean one Andy, can you post it?
Not yet :wink:El Barto":l8xac9bu said:Are either of them single bevel?
toolsntat":2hdskf0n said:Not yet :wink:
These may well be hard enough all over to take an edge on the side but remember the eye is not offset and the faces would need work for the edge to be clean.
Trevanion":1wxc29ct said:toolsntat":1wxc29ct said:Not yet :wink:
I don’t want to detract from the sale post and infringe rule 3 of the FS board rules, but weren’t these old Kent pattern heads predominantly made from a piece of mild steel bent around a form to create the eye then the cheeks forge welded shut with a piece of high carbon steel in between like a sandwich? If it’s done like that then possibly you wouldn’t be able to get an edge to hold sharpness if it’s ground to a single bevel as it would be on the mild steel part of the sandwich. I may be totally wrong though!
Mods, please remove this post if unacceptable.
Trevanion":dfm8ox40 said:toolsntat":dfm8ox40 said:Not yet :wink:
KimG":3uwai37s said:Just checking if you got my last reply Andy, I am OK with it Sans Handle.
