MattRoberts
How thick is your panel? Have you tested the strength of a magnet on one side and the metal on the other? You could just attach the metal on the reverse then.
Oh I see. Frog tape and magnetic paint could also work. Brushes on like ordinary paint but contains lots of metal. Does need rubbing down alot in between coats though. Think it cost about £10 from b & q.Tasky":2txyh8fi said:Magnetic plate, for sticking up various templates, game boards, reference charts, diagrams, notes, etc...ColeyS1":2txyh8fi said:Could you give us a clue what the metals for ?
ColeyS1":141hux82 said:magnetic paint could also work.
Oh, with the router supported on one side, not two, you mean? I would rather not do that with a hand router, but I can see it working well with the powered type.phil.p":2fap72m8 said:Start in the middle and work outwards, even easier.
15mm.MattRoberts":3u6o5zek said:How thick is your panel? Have you tested the strength of a magnet on one side and the metal on the other? You could just attach the metal on the reverse then.
That's what I'm using. Little tiny ones. I still have to carve the game pieces, and stick one of these things up the bum of each piece. Easier to do that, though, as it's just the right size drill bit.ColeyS1":3u6o5zek said:I wonder if neodymium magnets might stick better... umm
I'd planned to try that with just a chisel anyway, although no reason it wouldn't work with a router I suppose.bugbear":3u6o5zek said:All you do is LEAVE part of the area unrouted, e.g. work over the area making 1 1/2" wide routed strips separate by 1/2" unrouted strips. The unrouted strips act as supports.
bugbear":z5zolt5p said:Oh, with the router supported on one side, not two, you mean? I would rather not do that with a hand router, but I can see it working well with the powered type.phil.p":z5zolt5p said:Start in the middle and work outwards, even easier.
BugBearr
Tasky":zy02z1jv said:And the reverse will have something decorative on it - That's actually the outside face, when everything is assembled and closed up.
No-no-no-nooooooooo..... That's why I can't put the steel on the reverse, as Matt suggested... That, and the 15mm of oak between faces, of course! :lol:custard":3u4mggwy said:So the magnet has to operate through 14mm of Oak in order to grip the metal sheet on the other side of the wooden board?
AndyT":1utcyfwz said:He uses a hand router.
It may be too late to mention the other thing he does, which is to use plywood so he can see when he has cut through just one layer...
