Previously have surface mounted LED strips, hiding them behind shelf lips on angled profiles.
This time I'm looking at backlighting for a subtler effect, using a straight bit to router a groove the whole length of the shelf near the rear.
I'm a little apprehensive about the depth required for these recessed LED profiles. 8mm required (of my 18mm plywood shelf thickness). It's only for a 16mm width but was just look for guidance/comfort from those that might have done similar?
Thanks in advance
Thanks in advance
