10" thicknesser and planer advice
Jillos
New member
21 Feb 2025
WR11 8TL
Hi there,
I work with reclaimed wood, so a thicknesser is pretty essential to prevent hours of sanding.
As a newbie woodworker, I bought a basic Triton model from Screwfix, but the performance really isn't great. It doesn't handle the wider pieces that you get from euro pallets at all, so I'm looking to upgrade to something a bit more serious.
My needs are:
10" thicknesser so that I can thickness scaffold boards
Planer on the top
Single phase
And that's about it!
I'd be looking for second hand so that I can get something better for my money.
Budget is up to about £500. Don't mind if it's floor or bench standing.
Any advice on some options please? I've been searching equipment auctions, ebay etc, but would just like some advice on what's good and what's to avoid!
I'm sure this question has been asked before, but some up-to-date recommendations would be good.
Thanks all.
The only P-T I have experience of is the Scheppach HMS 260 10" machine, single phase. There's three for sale on e-bay at the moment.
It's been very reliable indeed, needing only one new capacitor and a drive belt or two in the 20-summick years I've used it (from new). If you look at a seond hand one, check that the rubber feed rollers are in good nick. These can be affected by extreme conditions, or so I read. Mine are still solid and unglazed after passing gawd-knows how much timber through them.
These machines, I believe, were made in Germany before Scheppach went rather downmarket. Their machines from 15 or more years back are of good quality whereas the latest stuff seems to be just Scheppach coloured & badged every-one-sells-it items, made in the Cheapies-R-Us factory far away and over the continents.
Don't buy something good. It was enormously frustrating at a men's shed that guys would bring along old pallet wood and other scavenged timber, even logs from roadside trees, and wreck our bladrs and scar our machine tables with the nails and embedded grit and gravel that these contain.
We tried scanning with a handheld metal detector (like security and bouncers use) but thes edon't catch everything and can't see stone, so we banned reclaimed wood altogether.
Agree with what Sideways said. The grit from scaffold boards will blunt blades incredibly fast, quite apart from any nails. How about a big belt sander for dealing with reclaimed wood?
If you start damaging machines, scaffold boards or pallets can be a bit of a false economy. You could always save the thicknesser for nicer bits without potential hidden horrors?
Thanks, yes I saw one of these in an auction recently, but couldn't work out whether it was singe or 3-phase - I think they do both - so I didn't bid. I would definitely go with one of the older ones (I think the one I saw was about 1990) as agree- the newer ones are just the bog standard 'last a year or so then dead' variety...
Thanks @alex robinson and @Sideways. You know, I hadn't even thought of that. Of course I diligently de-nail the pallet wood and use a metal detector, but the point re scaffold is a good one - they usually have all sorts on them.
I think I still want the thicknesser, but I'll have a look at belt sanders too!
Definitely get the thicknesser - they are great, but be gentle about what you put through it!
I got a Makita 9401 cheaply second hand recently and it is a game changer. Completely different beast to the flimsy rubbish 3 inch machines I had used before. The extra weight really helps both for speed and controllability.
Is that a 100mm belt? And is it an older or newer version?
For example, here's one that looks older (but heavier) https://www.ebay.co.uk/itm/22661012...uid=9i2Hi0pDSHW&widget_ver=artemis&media=COPY
Yes, 100mm belt. Weighs about 7kg! Mine is from the 80s I think. Cost silly money new, but second hand far better value than the same amount spent on something new.
There are a few threads about them here. Simple, heavy and bulletproof. I believe there are still spares available, but mine hasn't needed anything yet. Don't accidentally plug it in when switched on - makes a hell of a crash when it zooms off the bench!
Before buying a PT, I visited my local joinery workshop to get a ‘tutorial on the safe use of a PT’. They had a 14” Sedgwick with Tersa blades. Their solution was to use an old, chipped, set of blades for scaffold boards, before changing blades prior to final passes. Not the answer that I was expecting and only possible with a system which allows slick blade changes.
Hi
As well as the schepach (older ones) I’d consider the elektra beckum 10” HC260. I bought mine second hand a few years ago and it’s been great. Pretty sure it was made in the early 90s. I’ve heard decent reviews of similar models such as the metabo and later model elektra beckum ones (blue paint instead of green). It’s got 10” planing and 6” thicknessing capacity so probably similar or the same as the schepach and probably a few more of them to be had second hand.
Any timber I think is suspect gets a run over with a hand held electric plane before going to the planer or thicknesser. Blades for electric planes are cheap compared to those in your machines.
Regards
