1 MT Adaptor needed, Update this might help you!
petercharlesfagg
23 Jun 2006
South Northamptonshire
Friends,
I need a 1 MT adaptor that is parallel on the outside with approximately 1 inch OD.
My production work of dozens of Napkin rings means that I do not want to constantly remove the chuck to fit a drill chuck tasper into the headstock.
Any ideas?
I have studied the Axminster but the OD is too large.
Regards, Peter.
Peter
I hadn't seen your thread before and was impressed with what you found, but that did lead me to wonder quite why ?
I'm having difficulties seeing how you are holding the work-piece if the drill chuck is in the lathe chuck - and then I'm sure there's a perfectly good reason ....but why are you working what seems to be a***e over t*t ?
Rob
