Any bandsaw can be modified to run very small blades, easily and cheaply I've not used the Carter thingy, but I have seen and (briefly) used the Inca gadget that I think is functionally identical. It works well, but is very expensive as an aftermarket product.
I use a 1/16" blade on my Basato. I use the bearings that it came with, no aftermarket purchase. I simply cut a disk of 2mm MDF and stick it to the guide bearings with DS tape. I can adjust the bearing right up to the blade, supporting it completely, without the risk of damaging the blade with the guides, or the guides with the blade.
As the blades twists and turns, the disks get chewed up and have to be replaced, but that is no real problem as they are quick, easy and cheap to make.
I'm not familiar with the guide assembly for your BS, but I would e astonished if the same principle could not be applied to it.
