Excellent job, Richard. Splendid refurbishment, and a really good investment!
There's a small tip when refurbishing longsaws. Many of them seem to suffer from excessive sharpening in the middle of the blade, leading to a distinct hollow in the toothline (a hump in the toothline is not so bad - indeed, some saws were offered new with a 'breasted toothline').
Taking this hollow out can be a problem. I had one saw in which I jointed the ends until the tooth profiles had almost disappeared, but the middle teeth were untouched. I stopped jointing at this point, and recut the tooth profiles at the heel and toe, then jointed again, then recut profiles again. A straight wooden stick (doesn't have to be to split-thou accuracy) makes a good straightedge (tip copyright Bugbear, and it's a good one - a 2" x 1/2" or so stick is far easier to wield than a steel straightedge, and won't damage teeth).
