Ian down london way
I do love the interaction and encouragment on here - thanks guys.
I must admit, this kinetic sculpture was me taking a break from a hard(er) problem....
I have in the past made something called a marble chest, whose plans I got from Forrest Designs:
http://www.foreststreetdesigns.com/Marb ... _Plan.html
Really fun to show working, but it runs only for about 1 minute at most. The link has a video of one running, mine was made close to the plans. Apparently I have to make another similar one, as I've two kids and they are fighting over who gets it when I die. :lol:
So, having made some clocks, with varying degrees of success, I set myself the challenge of trying to combine a clock concept with the marble chest concept, so allowing a weight to be used to re-raise marbles back to the top of a marble chest type thingy - so it would keep running till the weight reached its end point - maybe 30 minutes.
I started with prototyping different ways of raising marbles, given some torque being available from a cog. I came up with 7 or so concepts - which operated in very different ways. I prototyped them all, but my second concept design was the most effective, although not the most asthetic. However it suffered from a run-away problem - it just got faster and faster, where as I wanted one marble raised every 3 to 5 seconds. I had to introduce some means of making it run at a constant speed.
Ah, that's what the escapement of a clock does - I hear you say - quite so. However, on a clock, the pendulum swings once every second or so, and gears down the hands to turn more slowly. Where as I needed to raise about 1 marble every 5 or so seconds.
So, I struggled with this for a couple of months, got rather frustrated. So, in need of envigoration, I decided to take a break in November, hence this item.
When its done, I'll either do another marble thing (there are four here: http://www.foreststreetdesigns.com/Catalog_page.html) or return envigorated to design my own beast.
So, here's a challenge, How many significantly different ways can you think of to raise a marble using the power of a falling weight.
Enter your ideas here in this new thread: raising-marbles-using-gravity-t67070.html
(NOT IN THIS ONE !!!)
