"]Acquired this machine a few weeks ago. Early eighties version. Machine No. 12"BAO/S 825347. Nice clean example with original paintwork. I need to convert it to run on 240v single phase supply and change the cutterblock to a Shelix spiral one.[/quote]MilesH[quote="MilesH":3inyx79c said:Thanks wallace, that's interesting. I noticed that the machines Wadkin exported often had dual voltage tags.. My AGS (1977) is wired for Wye only. This BAO/S is 1982ish so, it's possible....wallace":3inyx79c said:I've had motors in the past that only showed one voltage on the tag but were changeable in the box
Ian Mellin":2slgvlo0 said:"]Acquired this machine a few weeks ago. Early eighties version. Machine No. 12"BAO/S 825347. Nice clean example with original paintwork. I need to convert it to run on 240v single phase supply and change the cutterblock to a Shelix spiral one.MilesH[quote="MilesH":2slgvlo0 said:Thanks wallace, that's interesting. I noticed that the machines Wadkin exported often had dual voltage tags.. My AGS (1977) is wired for Wye only. This BAO/S is 1982ish so, it's possible....wallace":2slgvlo0 said:I've had motors in the past that only showed one voltage on the tag but were changeable in the box
