duncanh
I was asked in another thread why I'd chosen the Ultima (medium version) over the Munro (original, large version). Well I actually didn't, I chose both
. Here's why, with a few thoughts on each.
I've had the Munro for about 4 years now but it always had a few shortcomings for me-
1) it's sometimes difficult to adjust the cutter shield to take exactly size of cut you want. When going in for a final finishing cut you want to set it so it takes a minimal shaving but I always found this a bit hit and miss to get right. I sometimes end up taking too little, resetting and then taking too much.
2) my Munro is one of the original ones with the off-set head and I found it difficult cutting across the bottom of the form I'm hollowing. This is probably easier with the new head and I was able to improve things a little by grinding a tiny amount of the cutter shield on mine but, but I usually end up using a scraper.
3) the bar diameter on the Munro is only 1/2" and vibrates when you start doing deeper hollowing. I got round this by mounting the head on a 3/4" bar used without an end handle and (but with the side handle from the Sorby Slicer) but it was cumbersome to use.
The reasons I considered the Ultima are that it address all those problems-
1) the cutter shield can be finely adjusted using the knurled ring just behind the cutter head
2) the cutter can easily be set to cut on the end
3) the bar is thicker
4) the long handle if great and well thought out - I can easily add a side handle (can be bought but I discovered that the stem from my Sorby modular rest has the same thread ). If I feel the need I can add weight inside the end handle (screwed in to the back of the handle end). I can also add extensions to the handle if need be. The handle comes with several sleeves allowing me to use it on regular round tools.
5) I saw the Ultima demoed by Sorby at our club the weekend before Harrogate and liked it. The head has a bevel on the back of it so in theory it's possible to rub the bevel and get a good finish.
I used the Ultima for the first time yesterday and here are my thoughts after about 2 hours use (in no particular order)-
1) It can take big cuts and you need to be careful how you set the cutter shield. Big cuts really pull the cutter into the wood.
2) It was a little tricky, despite the ring adjuster, to get the right depth of cut.
3) When cutting well the shavings exit the cutter and get ejected very cleanly. Very similar to the Munro but with slightly different trajectory. Not sure if one trajectory is better than the other.
4) It didn't always cut well and the cutter and shield were a little prone to getting clogged with debris.
5) Rubbing the bevel does work but I seemed to get vibration in the head fairly quickly. I just need to find the right amount of pressure to apply.
6) The 2 allen screws controlling the shield have their heads on the top which means they get shavings in them that should be cleared before you adjust them. I queried Sorby on this when I bought it and suggested that it might have been better to orientate them the other way up (it was a specific design feature of the Munro) and they laughed and said to just clean them.
7) The straight bar has a thicker section at the end where the cutter is mounted and this makes it impossible to get the rest right up close to the entry to the form and to cut there. This probably isn't too much of a problem and I just need to get used to it.
8 ) Having a side handle is great, and works really well.
Obviously I'm comparing several years of Munro tool use against 2 hours of Ultima use, which is a little unfair, but then that's all I've got for comparison.
I'll try to keep this updated whilst I continue to use the 2 tools.
Ultimately I'm expecting to sell the Munro.
