Single fence DADO sneaker upper er
I've seen a similar router base but it was hexagon shaped and each face steps in by 1mm.
barkwindjammer":14xznp8s said:
A crafty little easy to make gizmo, allows you to sneak up to those dado widths using an undersized bit, a single straight edge/fence and away you go........wonder if someone could run these up in acrylic (group buy)
fast forward to 1m40s
http://www.youtube.com/watch?feature=en ... bxI4A&NR=1
Thanks for the tip - simple enough to make the base. But I would be interested in a group buy.
Dave
