condeesteso
I have been following the Stateside interest in these for quite some time, and decided to make a couple (the reason for 2 will follow).
Basically the idea of raising the workpiece sometimes is useful I think, and a bench height is a compromise: lower to get over the work, higher to work into the piece.
Anyway, without a whole bench to build at the moment, the fingers were getting a bit itchy.
An Axminster 1 1/2" screw cutter, some bits of beech and a scrap of oak:
The Axi screw -cutter is really good for £40. I needed a couple of practice shots first, but it works very well. I would say the linseed soak is really worthwhile. And I did a silly thing. I thought back the cutter off and take 2 bites, but obviously the reduced thread depth won't clear the threaded exit guide in the die, so wrong. Go to depth in one hit.
The pitch is slow compared to the big custom-made wooden vice screws, it is 6tpi, but it is OK for a small-scale vice.
The twin-screw is a really interesting vice anyway with talents all of its own - in particular clamping close to one screw and use the second to apply final clamping (leverage effect), or clamp outside of one screw and back the further one to tighten more. I like twin-screws.
V2 will have a few small mods, so I'll report back. V1 is 'going out for test' later this week. That means part repaying the Jim debt :lol:
