Steve Jones":1yum1uft said:--- but isn't the title 10 years out of date ?
Steve
Jonzjob":2vca9iwo said:......Antipodean Burr, what is it? Looks good what ever it is???..
cambournepete":2n0jme09 said:Hi Chas,
How do you finish the rough part of the burr?
I can see it's shiny so I'm guessing a spray lacquer, but how do you prepare it before that?
nev":1bts45t0 said:.....pencil pots, could i ask what glue / adhesive you use / recommend to join the various woods?
CHJ":j42zgwfr said:nev":j42zgwfr said:.....pencil pots, could i ask what glue / adhesive you use / recommend to join the various woods?
The method I use is detailed on my site, Specific Link
You need to make sure both surfaces are covered, you need maximum surface area bond, both surfaces must be absolutely flat.nev":1h45t5zh said:.....when applying the CA , do you apply one thin bead centrally all around?
I'm with you there John in general terms, in it's defense it is more stable than at first impression because of the thin walls the bulk of the weight is low down, so it's virtually self righting.Jonzjob":178lwvqq said:....... The first is OK, but I have never been a great fan of very small bases on bowls/goblets/etc. I love to see the elegance and stability of something that won't fall over when in use. ....
