Paul.J
I turned this Spalted Holly bowl some time back,which developed a small split in the side.
So after seeing George Fs piece the other week that gave me the idea to do something similar with this piece.....
and this is the result.
After marking the cut out lines on the bowl the idea of a mountain range came to mind so went along with taht theme,four pekas sos to speak :lol:
I decided to paint the inner black to give contrast against the white outer and so that you could see like a silhouette effect.
Then i remembered seein some where in the lake district a small lake right at the bottom of a range of hills,so i turned a small oval shape and stained that blue to give me my small lake.
Then i thought about having a path leading all round the top edge of the piece,so the eye follows it all theway round,so pyro'd that to give a well beaten pathe effect.
I don't think i'll be rushing to do another,but it is good way of using a piece that splits.
So critique will be welcome on my first ever,and probably last painted piece
