9fingers
Over the last few weeks I've been installing Barry's Cylcone in my workshop
The blower, fitted with a 3HP 3 phase motor is mounted in a frame of aluminium angle and suspended from the roof rafters partially above the ceiling level.
The outlet of the blower is connected to the silencer which is suspended from the ceiling and feeds the micro filters (not pictured). In the background the cylone is mounted on the wall.
[/img]
Another view of the blower -silencer combination.
[/img]
The blower frame is mounted on rubber anti vibration mounts and the motor is driven from a variable speed inverter so that it there are any nasty resonances, I'll be able to programme these out with the inverter.
The dust collection bin is loose on the floor directly below the cylone.
[/img]
As an experiment I have made a 1 minute video with an audio commnetary of the installation including the 8 downpipes and blast gates using 110mm drainpipes.
I hope this works out ok and plays ok. I suggest that you dont follow the link if you have a slow dial up link.
http://s115.photobucket.com/albums/n313/9fingersphotos/?action=view¤t=Mvi_0217.flv
All is working well with no vibrations being transmitted through the roof which was a concern.
Bob
[/img]
[/img]
[/img]
Bob
