I was trying to test the moisture content of some air-dried, milled wood today. It's a damp day and the wood's still in stickers, under cover but open to plenty of moving air. It's a very damp day here in South Wales.
Putting the probes into the outside of the wood, the wood measured about 30 percent. Cutting a small piece off with a hand saw, the wood registered 18pc mc inside. A piece we planed on a planer a few days ago was 18 pc mc after a few mm from the surface had been removed, but had gone back up to 25 pc after being stored in the same damp air, under cover.
I guess the action of sawing/ planing can raise the temperature some and maybe dry the surface revealed, and assume the outside of the wood (usually drier than the inside) is holding some of the moisture from the air. Both of which would give a reading that's wrong in relation to the inside of the wood?
How I'm supposed to know the true moisture content of the wood?!
Thanks, Chris
Thanks, Chris
