Hi all - newbie here just setting out on woodturning. Just got a brand new CL4 and am trying to assemble it. Has anyone else fitted the motor into the headstock as I am having a problem?
The motor shaft is supposed (according to the instructions) to have a flat spot to allow 2 grubscrews to be inserted into the pulley to hold the pulley in place. However the motor shaft does not have a recessed flat spot - it instead has a keyway fitted into a slot in the end 25mm of the shaft instead. The pulley supplied though has a round centre shaft without a keyway recess so it will not slide onto the motor shaft . So either the pulley is the wrong one (maybe from an earlier CL4 model) or else the motor shaft will need the keyway drifting out.
I expect I will have to speak to Record after the long weekend but thought I'd just check... I've already had about multiple phone calls /emails about missing / wrong parts with the initial delivery a week ago so not too impressed so far...
