New Axminster AWVSL900 or second hand Record Power CL4 lathe
mike-bolton
13 Dec 2013
Merseyside
Hi
Need help buying a new lathe I'm stuck between these two I dont know whether to buy the axminster lathe with the three year guarantee or rist buying the CL4 that also needs new bearings fitted.
It would depend on what price is being asked for the CL4. If the same price as a new awvsl900, then I would go for the CL4. You will never match the build quality of the CL4 with a hobby series lathe, although the 900 may cope with all you will ever want to do.
Even fitting the new bearings isn't a major operation, and if you feel it's beyond you, then pay for an hours labour and you will have a very respectable piece of kit which is pretty bullet proof.
Phil
+ 1 to what Phil says. I have had my CL4 for 14 years now and have only changed one bearing. It does everything I want plus some !!
F.
Hi
Another vote for the CL4 - mine has never missed a beat in the 12+ years I've owned it :D
Strangely enough the lathe I replaced with the CL4 was an AWVSL900, (under a different 'badge') - the build quality is miles apart as is the variable speed systerm. As a first lathe the AWVSL900 clone was OK but after a couple of years I decided to upgrade and have never looked back.
Regards Mick
Whats a set of bearings ie the secondary and the bronze for a cl3 /cl4 cost to buy these days. I have a in the bag brand new set and should sell them rather than they just hang around the shop.??
Rend.
Hi,
Both lathes are £280 but it would cost me £70 to pick it up and around £70 for new bearings where as the axminster is free shipping
Hi
No hesitation - the CL4 will be better on all counts.
Is the seller getting rid of any other turning paraphernalia which could offset your start up costs even more?
Regards Mick
Afternoon Mike
Are you sure the CL4 needs new bearings?
If you register on the Record Power site you can download the manual, which covers both bearing adjustment and replacement.
Dave
Deejay":c4n4wx2i said:
Afternoon Mike
Dave
+4 I've had mine for 12 years adjusted mine twice Built like a battleship I bet its not worn any way renderer01 as one if needed
Geoff :D
Grahamshed":bu3rja29 said:
I am voting for the Axi
Cos all this is getting way to one sided
Hi
It will probably be the same price as a new CL4 come tomorrow's price rise :lol: :lol:
Regards Mick
Oh don't. I am dreading what it will do to the 16/28 and all the bits I want but just can't do it yet.
Mike, have you used either of these lathes (generically, not necessarily the specific machine)? Others will have a view on which is 'better' but personal preference will have a strong part to play. For me, I can't get on with the twin bar, record arrangement so would prefer the cast format of the APTC machine but that is me and it is your money.
I'd suggest trying to use a similar format machine to each as that may make your decision for you.
My 2p anyway.
Simon
