thirsty
After some time experimenting with away to transfer patterns on to wood rather than taping a paper pattern on I have finally developed a medium to do this.
As you can see from the picture the pattern is printed directly on to the wood using an inkjet printer and my A4 sheets of medium transfer rather like screen printing.No heating is required and the sheets can be used a number of times.
The system works with most inkjet printers that don't automatically detect the type of paper used ie:Kodak Printers.
Just print out your pattern making sure you reverse the image in the program you use or your printer setting and transfer to your wood. sorry the pictures are not that good.
Mod edit:- direct advertising removed.
