j
Hi,
I've finally managed to find a bit of time to go and have a look at the TS-200 I bought last week
After attaching the fence rail, the first thing that I found was that the fence was not running square to the mitre slot.
It runs away from the blade by almost 3mm at the leading edge of the blade.
This means that ripping some thin strips (like for the mitre slots) I end up with some interestingly tapered pieces of wood.
I know the fence is generally considered worthy of an upgrade, but I'd hoped to be able to get by without spending the extra for now. I can't see any way to adjust this though, what am I missing?
Given this issue, I ended up planing down a short strip to fit in the mitre slot so that I could use my dial indicator to see if the blade ran parallel to the slot.
The indicator showed that the blade was out by about 0.2mm relative to the slot.
I also found that it had about the same 0.2mm runout turning the blade and keeping the indicator in one place.
I'm assuming these figures are acceptable, but the fence isn't.
When making the runners for the slots, I've measured them to be 15.2mm at the top, and about 6.9mm deep. My plan was to just use 15.2mm strips of wood, and not try to produce T-slot shaped runners. Would this work?
J
J
